In October I took off the heads with the engine in place. This revealed worn valve guides but also showed some scoring in the cylinder bores.
So out came the crossmember, block and gearbox.
On strip down 5 of the eight pistons had broken top rings, worn con rod, big end and camshaft bearings. Surprisingly she didn't lay down a smokescreen just a puff on overrun and the performance wasn't that bad.
The engine is a 260 and has already been bored to .030. Cam fitted was a standard 289. Edelbrock performer 289 inlet manifold, tubular headers, Holley 600 carb and Mallory distributor. The oil pump was a high volume high capacity unit - fitted in 2009 by a previous owner. Sump was standard 5qt.
So what to do. Junk the motor and fit a 302 or rebuild the 260.
Costings worked out cheaper to go the 302 route. But there are so few 260 Tigers left that I decided against the sensible option and will rebuilt the "boat anchor". But with a few modifications.
It would be interesting to know how many 260 Tigers remain in the UK these days.
*** TO BE CONTINUED***
A bit easier without the heads, but still a pain.
Broken rings.
