Bad earth on rear lights MK1 Tiger
thdxb08
Post by thdxb08 » Mon Jun 07, 2010 7:59 am
Can someone advise me where the earth for the rear lights?
When I indicate left the indicator flashes with the side light, I assume this must be a bad earth.
V Mad
Post by V Mad » Mon Jun 07, 2010 8:05 am
Going from memory I think the lamp holder is earthed via the mounting screw/nut; I dont think there is an earth wire. Try removing the lamp assembly, clean up the metal on the body, and refit the nut with a serrated washer which will bite into the metal. Use some copper grease after to seal it.
Chris :-)
1966 Mk1 260 Tiger
!972 Triumph Stag 3.0V8
www.stagweber.co.uk
