Wheel sizes
Shindles
Wheel sizes
Post by Shindles » Mon Dec 13, 2021 6:54 pm
Will 8" Minilites fit my standard Mk,1A Tiger?
If so what tyre size is recommended?
Re: Wheel sizes
Post by garyf » Wed Dec 15, 2021 2:50 pm
I have 6" wide rims 13" Diameter on my Car with 185/70 Tyres with no issues, the off-set is the important thing but I would guess 8" wide would be marginal.
The Tyre Selector for 8" Wide rims suggest 225 or 235 is ideal with 215 the minimum which will safely fit, you don't say what diameter the Rims are?
15" seems a popular size for most Tiger owners, I'm sure someone will know, but responses on here seem to be limited :cry:
If you do Facebook it may be worth asking the question on the UK Tiger Group?
Shindles
Re: Wheel sizes
Post by Shindles » Wed Dec 22, 2021 7:52 pm
Thanks Gary, I'm on 15" wheels.
I'll ask Minilite directly, and measure the wheel arches to estimate.
Re: Wheel sizes
Post by Brad1380 » Sun Jan 02, 2022 6:47 pm
Its the inner wheel arch and the outer arch lip that causes problems, to go 8 inch is best done when welding up to give clearances, you may be lucky with your set up as it is but probably not.
RR
Re: Wheel sizes
Post by bigbob » Tue Jan 04, 2022 11:14 am
I've had 15x6" front and 15x7" at rear fit ok, but tight. 8" might be a touch too far without modifications
Shindles
Re: Wheel sizes
Post by Shindles » Thu Jan 06, 2022 5:14 pm
Thanks, I'll stick with 7 inch.
