Hi Mal
On my Quicktime the starter mounting points (circled below) were a threaded insert, however the spacing, either on the housing or on the starter mounting face, was mismatched and as such my starter wouldn't mate to the housing. To resolve, I had to drill out the inserts and resize.
I couldn't re-tap the housing with the insert gone, so I have used longer ARP bolts instead. The bolts are shouldered (rather than threaded to the head) and locate the starter nicely. I will finish off properly with lock nuts/wire once I mount the bellhousing/starter nose cone. By the way, I thought I had ordered the correct starter first time around, but stuffed up. I am using a 157T flywheel. I have a brand new 164T M/T hi torque mini starter should you run into strife!
The hi tech marks are to allow me to index the starter - I have to rotate the starter body to mount up to the housing, then rotate it to move the solenoid away from the headers. The starter allows quite a lot of rotation.
Hope this helps, Cheers Tom
