Post
by garyf » Thu Jul 05, 2018 4:26 pm
Can anyone help with an annoying steering column rattle/knock I get when accelerating, its worst whilst turning and accelerating.
The noise sounds like something catching the Column, I've checked all the mounting bolts and pinch bolts on the lower UJ's and all are tight.
The steering wheel is also tight with no play
Could it be a worn upper bearing or something loose inside the column, the telescopic mechanism perhaps?
bernd_st
Post
by bernd_st » Thu Jul 05, 2018 10:01 pm
Hard to diagnose just by description. Worn upper bearing could be the cause and it's very common...
tgr747
Post
by tgr747 » Thu Jul 05, 2018 11:02 pm
Has your car got a generator,sometimes it can catch and give the symptoms you have.
Post
by garyf » Fri Jul 06, 2018 9:02 am
It does have a Dynamo (Generator) with very tight clearance so will check its not catching the column?
The top bearing is a possible too
FDub
Post
by FDub » Sun Sep 30, 2018 10:45 pm
I have the same issue. Slight interference somewhere under WOT, upper RPM.
I grin and think of it as “character”
Post
by garyf » Thu Jan 09, 2020 11:09 am
tgr747 wrote: ↑Thu Jul 05, 2018 11:02 pm
I've finally resolved this problem and tgr747 you were spot on!!
See other post reference "Dynamo Clearance Issues"
