Possible Inspection Cover
Hi Brad
Mine's not 100% resto correct, but I made a small access panel at the lower reach of the rear of the inner front wheel arch (try saying that after a pint or 3) to allow cleaning/flushing/oiling of the inner sills. I see you have a similar area currently exposed - might be an option to consider?
Per Martin's offer, I can also send you some shots of the wing area if you require as my HRO is still in turkey mode...
Tom
Tom
Rough Shots
Hi Brad
Difficult to get same angle with bloody valance in the way, so I've snapped a few in and around. There's also my little support brackets (non OE) that are in the way slightly, but a worthwhile add in.
Hope these help. Tom
Looking in through front rail/bumper irons support. Still on turkey roller so that's in the way as well I'm afraid
From the other side of the RHS rail, again through lower valance
Same side RHS, from inner arch
And a couple looking in through rad support panel at inside of LHS rail/valance top join
Bit of work to do to the rear section of the n/s front wing, the top part with the splash shield has completely rotted out the splash shield was like lace, the previously fitted rear wing repair section doesn't fit & theres more holes by the sills, repaired a rather large hole in the inner wing already.
Hi Brad,
It is held to the floor by 2 brackets that it screws to and simply leans against the bulkhead.
The brackets are held to the floor by 2 pop rivets each.
You should find 2 sets of 2 holes about ( working from memory here) about 2 inches apart, about 4 to 6 inches towards you from the bulkhead which is where they are riveted down.
I'm at the outlaws at the moment but if no-one jumps in first I'll gets some pics for you later if you like.
