Cross member
tigertim
Cross member
Post by tigertim » Thu Dec 24, 2015 10:35 am
Dear Santa.... Do you have two lower wishbones the lower right would do.
If you have any dimensions to check the true, and pictures of cross member strengthening brackets that would be fine. :cry:
Post by martin172 » Thu Dec 24, 2015 1:52 pm
Search 'Crossmember' on the CAT forum and talk (pm) Randy Willett (oneoffive).
He overhauls and upgrades them. He should be able to tell you all you need to know.
Btw, Randy is a forum user on here too.
tigertim
Post by tigertim » Thu Dec 24, 2015 3:52 pm
Thanks Martin. I have found all that info. I was living in the vein hope that there maybe one in the UK. I have the ability and equipment to straighten them myself. what I would like is any info on measurements for the cross member. In its previous life it looks like its had a smash on the right side. whilst the car has been driving fine it wasn't until I took it apart I could see the damage. More annoyingly someone had put back together bent as all the packing in the right spring housing fell out when apart. At least I now know why my car sat low on that side.
Post by martin172 » Thu Dec 24, 2015 4:55 pm
Talk to Randy.
Front cross members are a speciality of his.
He's helped me with info in the past. Very nice and helpful chap.
If you put a similar thread up on CAT and he'll be along.
Does suspension too...
http://www.ebay.com/itm/Sunbeam-Tiger-A ... Rg&vxp=mtr
tigertim
Post by tigertim » Mon Jan 04, 2016 6:09 pm
Martin. Update on the cross member. I spoke with Randy today and got the measurements required. Bad news is that I have a bent cross member which is out by 1/2-3/4" across the shock towers which would account for no shims that side. Good news, I have a complete Alpine Cross member I found 5 miles from home, will start remanufacture to Tiger cross member this week.
Post by martin172 » Mon Jan 04, 2016 10:17 pm
tigertim wrote:Martin. Update on the cross member. I spoke with Randy today and got the measurements required. Bad news is that I have a bent cross member which is out by 1/2-3/4" across the shock towers which would account for no shims that side. Good news, I have a complete Alpine Cross member I found 5 miles from home, will start remanufacture to Tiger cross member this week.
Shame that your suspicions were confirmed but isn't it nice when you find what you want just up the road. :D
0neoffive
Play Safe
Post by 0neoffive » Tue Jan 05, 2016 4:16 am
Good Luck on your project. A cross member is bit of a challenge, but some patience and thought will win out.
Post by Mal » Sat Jan 09, 2016 7:52 pm
All these series Rootes Group X members are basicly the same. I have one here from a series V Hillman. Which measures up the same as the Tiger
X member. I was told by a local Sunbeamer who has played with these cars for years along with the Super Minx cross member.
tigertim
Post by tigertim » Wed Jan 13, 2016 9:43 pm
X Member completed and test fitted ready for the paint tomorrow.
Just to say thanks to Randy and Martin for your help.
0neoffive
More Input
Post by 0neoffive » Thu Jan 14, 2016 12:06 am
We always place an extra surface plate over the thin area just below the track rod detents. Both perimeter welded and button hole welds for strength. Be sure to hammer shape the piece into the indent area where the lower wish bone fulcrum mounts.
tigertim
Post by tigertim » Thu Jan 14, 2016 1:16 am
Randy. By making the filler in three parts I was able to shape the vertical section as a one piece gusset which runs from the inner lower bulkhead to just beyond chassis bolt holes and runs just beside the access hole in the bottom and welded all the way. all in 2mm plate, hope that makes sense.
0neoffive
Beef It Up
Post by 0neoffive » Thu Jan 14, 2016 1:42 am
tigertim wrote:Randy. By making the filler in three parts I was able to shape the vertical section as a one piece gusset which runs from the inner lower bulkhead to just beyond chassis bolt holes and runs just beside the access hole in the bottom and welded all the way. all in 2mm plate, hope that makes sense.
Got your meaning. What ever strengthens that design weak area is a good benefit no matter how you approach the issue . . . . .good lookin' workmanship.
tigertim
Post by tigertim » Thu Jan 14, 2016 1:53 am
I've had 35years or bashing farm machinery into shape when the staff break it. give me a hammer, gas and welder. Big Bob may have many different car parts on his car, but I bet he hasn't got Massey Fergusson!!
Post by Tomaselli » Thu Jan 14, 2016 5:18 pm
That's mightily impressive work there Tim! Excellent stuff!
I have 600 lbs (stock is nearer 200 lbs IIRC) front road springs and the Koni shocks are on medium (ish) setting. Have been told that the shock turrets on the crossmember would be best seam welding all around, something that some of the race boys do.
Haven't done that as yet...... touch wood I seem to be fine :shock:
Worth doing Tim? for peace of mind depending upon the direction you are taking with your setup.
tigertim
Post by tigertim » Thu Jan 14, 2016 9:03 pm
Thanks Tony. Randy did suggest just that, so I have welded towers at top and bottom. I have HD springs from Sunbeam spares, not sure what lbs they are. Off to see Red Barron tomorrow. He's building me a 289 5 bolt. Engine bay and X member sprayed today. I have no idea how I am going to get the engine back in without scratching it.
