Post by Brad1380 » Sun Jun 08, 2014 6:25 pm
Well not a lot of progress on the Tiger due to the building project, but i have reached a milestone with that now so hope to pick up again on the restoration soon.
Done these so long agao now i've forgotten where they fit.
Not a good idea pulling the torch out of the welder when its running, fixed it eventually & fitted a euro torch conversion.
Ebay bargain scatter sheild, post shot blasting.
Took the hood frame apart, i thought matching the grey would be a problem, but once the vinyl was off the colour was much lighter, match was just standard light grey.
The flywheel is very rippled & with some cracking....
Tank dipped the block, then ran a Mercer bore gauge after a light hone to tidy the cylinders up.
I set the gauage at 3.803 as per the manual, i was getting readings less than this, i.e smaller diameter, but even with that the block looks well worn, with no.6 piston especially going wander about, thats a difference of 65 thou top to bottom.
Oh well i guess it opens up a whole new world of engine choices i suppose.
redbaron
Post by redbaron » Sun Jun 08, 2014 11:21 pm
Brad,
the bellhousing that you have is not a Scatter Shield,but a cast iron 302/351 truck bellhousing.Dual bolt pattern transmission.
This iron bellhousing will shatter if the flywheel disintegrates,a true scatter shield is made from ballistic steel.
Lakewood are a reputable company for such,although fitting into a Tiger is tight due to the drawn depth of the B/Hsg.
Shelby American did make some Hi Nodular iron B/Hsgs in the sixties,yours is from the seventies.
Bit to heavy for a sports car.
Post by Brad1380 » Mon Jun 09, 2014 7:35 am
It is heavy!, oh well i'll sell it on again.
Post by Brad1380 » Wed Jun 11, 2014 5:19 pm
Been looking at a RS engine from Realsteel, not that expensive really when you start to tally up the parts & machining.
http://www.realsteel.co.uk/section2a.pdf
is there anything i should swap over or be aware of? any help would be appriciated as i'm new to V8's.
Post by pushrod » Thu Jun 12, 2014 9:11 pm
The RS motors are good value.
As a comparison I spent more in parts and machining costs on my 260, that's without any labour.
If I hadn't wanted to stay with a 260 I'd have gone for one of the RS 302's in a heartbeat.
Post by Brad1380 » Fri Jun 13, 2014 4:46 pm
Does anyone know if the head ports on the RS motor are the same as standard? so i don't have to fabricate new exhaust manifolds like Mal did.
Post by meadowhog » Sat Jun 14, 2014 11:24 pm
Those panels look like the inside covers of the soft top frame. They fit to the vertical hinged part when roof is up.
Post by Mal » Mon Jun 16, 2014 9:24 am
Brad1380 wrote:Does anyone know if the head ports on the RS motor are the same as standard? so i don't have to fabricate new exhaust manifolds like Mal did.
My heads were GT40P heads which are from Ford. Pretty sure they are the only head made by Ford with different a plug angle which causes the problem. As for aftermarket heads I don't know.
Post by Brad1380 » Mon Jun 16, 2014 3:57 pm
meadowhog wrote:Those panels look like the inside covers of the soft top frame. They fit to the vertical hinged part when roof is up.
Thanks, i guessed they were part of the hood from the colour but i never took a photo of them in place.
Post by Brad1380 » Mon Jun 16, 2014 4:03 pm
I know the GT40 heads are the best, thats why you have them ). I need to have a long chat with RealSteel, but first i need a solid body, hopefully get onto that again now as i'm fed up building....
Post by Mal » Mon Jun 16, 2014 7:44 pm
Brad my heads are GT40P heads not GT40. tHE GT40 HEADS have the same spark plug angle as the 260-289 302 heads.
Is that another restoration project ?. Do you have a before pic.
Post by Brad1380 » Tue Jun 17, 2014 6:41 pm
Mal, thats probably the best photo, before it was rather dark in there, i can tell you that as it was an old cow shed the floor was on a slope for all the cow urine to flow out, i had to take 120 tonnes out of there to get the new floor base right. You can see the old floor marks on the walls.
Post by Brad1380 » Tue Jul 15, 2014 9:47 pm
This was rather bent up before, flattened it out & sorted out the broken latch.
First test of the repaired welder as the sprung pistons had come away from the aduster.
Post by Brad1380 » Sun Jul 20, 2014 6:35 pm
Got this far with the Brembo disc spacers before the F1 race, will finish then off when the fasteners arrive.
Post by Brad1380 » Tue Jul 22, 2014 5:41 pm
The repair panel for the OS front part of the rear wheel arch was a bit out.
Had to let in a 3/16 slither to get it looking right, need to make up the inner wing section next.
The welder is going better now with a proper torch conversion.
