MK II Tiger Alternator Brackets
We have an opportunity to do a short run recast of the MK II alternator bracket, as original, in high strength aluminum. The minimum order for 11 of them would run $4,600.00. The initial pattern and core boxes are the high costs, while the actual raw casting is a bargain. Machining eats up a few more dollars. The final costs would be $425.00 US each. If there is enough interest, I'll turn the smutty-nosed foundry cats loose on the project. randy
