Various Parts Wanted
stuartb
Post by stuartb » Mon Feb 02, 2015 7:43 pm
Hello my name is Stuart, this is my first post.
I have a 1965 mk1 Tiger 260 RHD (project), below is a list of parts I am missing if anyone has any going spare.
R/H Exhaust Manifold.
Header Tank.
Radiator bottom hose Aluminium section.
Radiator.
Gear Stick.
Servo.
Air Filter Top & Bottom Plates.
Front Timing Cover.
Oil Pick Up Pipe & Strainer.
Thankyou in advance
Stuart
Post by bigbob » Tue Feb 03, 2015 4:00 pm
Hi Stuart, welcome to the forum. You have certainly picked a selection of hard to find/expensive bits to locate.
Exhaust manifold, header tank, air filter, & bottom hose section especially tough. You may be best going with after market headers, air filter, & servo to get you going & slowly pick up parts as you go.
Post by Tomaselli » Tue Feb 03, 2015 11:25 pm
Welcome Stuart!
Yes, as Bob says some of the parts you are looking for are not easy to get hold of, but they are out there - so keep looking.
On the bottom rad alloy hose bypass, I hear that a specialist may be looking to have some new ones cast. They have been reproduced before now, and I know that there is a bit of a demand for them now as the originals starting to perish over the years.
Are you keeping your Tiger stock and standard, or can you use aftermarket modified parts. Such as Lockheed brake servo and alloy radiator.
stuartb
Post by stuartb » Wed Feb 04, 2015 4:43 pm
Thankyou for the welcome.
I have a lot of work to do before the parts I am missing will be needed so I think its a case of waiting and keep looking.
At the moment my aim is to keep the car standard looking but will see what turns up.
As for Ali Radiators are they a big improvement or is an original radiator with a moderm better flow core fitted as good?
Stuart
bernd_st
Post by bernd_st » Wed Feb 04, 2015 6:11 pm
Following your aim to keep car looking original it's better to recore the original rad. Cooling performance is same if not better and alu just doesn't look right. No problem for a race car though but for street use no need. Just my 2 cent...
Post by Tomaselli » Wed Feb 04, 2015 9:29 pm
stuartb wrote:is an original radiator with a modern better flow core fitted as good?
Indeed, especially as Bernd says - if you keep the engine tuned for the road. I would throw in an electric fan at the front of the rad, and you are good to go in modern traffic.
Black stock rad does look nice in the engine bay.
On the subject of a servo, I have seen modern Lockheed units which tend to be more reliable fitted under the dash which keeps it away from the heat in the engine bay.
Post by bigbob » Thu Feb 05, 2015 10:50 am
My servo is fitted in a fake battery box under rear seat. Fuel pump in boot.
Leaves engine bay less cluttered & doesn't take up leg room in car.
Re: Various Parts Wanted
Post by garyv8tiger » Sat Feb 07, 2015 7:13 pm
I have header tank ,alluminum elbow .(ive got the air filter too but not sure if I should sell .but I would let the other bits go .but as the guys say there not cheap
Post by tigerman7347 » Sat Feb 07, 2015 7:23 pm
Hi Stuart, I have a gearstick which I had rechromed , no knob but they are available. Rob
sbt302
Post by sbt302 » Mon Feb 09, 2015 9:24 pm
I've got a couple original radiators to choose from...I can re-core them also.
might have the timing cover and pick-up pipe...i will av a look at weekend. 8)
sbt302
Post by sbt302 » Tue Feb 10, 2015 9:38 pm
I also have a pair of exhaust manifold you might need..
Post by Brad1380 » Wed Feb 11, 2015 3:00 am
You can still get the girling servos.
0neoffive
Post by 0neoffive » Mon Mar 09, 2015 8:40 pm
stuartb wrote:Hello my name is Stuart, this is my first post.
Header Tank.
Radiator.
Gear Stick.
Servo.
Front Timing Cover.
Hi Stuart: Got all of that except the air cleaner which Warren can fix you up with. Send me a mail for details. Randy at: < willett581@msn.com >
