I have a new project that requires some metal (aluminium) polishing. The aluminium has been glass beated, so I will obviously need to sand back the glass beaded surface. This is where some advice would be helpful in regards to achieve a nice polished finish. Any particular products (other than sand paper) that can help?
Thanks, Robin.
Metal polishing tips
Re: Metal polishing tips
I assume you mean beaded? as in glass bead blasted..?
If you want a professional finish buy a metal polishing kit with the correct pumice compunds and jewelers rouge... thats if you want it to look professional.
I would also check very carefully why LAT valve covers have their ribs removed at the rear vs normal ford cast alloy rocker covers... check your firewall clearence.
