Metal polishing tips
Post by gtsmrt » Wed Aug 10, 2011 11:30 am
I have a new project that requires some metal (aluminium) polishing. The aluminium has been glass beated, so I will obviously need to sand back the glass beaded surface. This is where some advice would be helpful in regards to achieve a nice polished finish. Any particular products (other than sand paper) that can help?
Thanks, Robin.
Re: Metal polishing tips
Post by michael-king » Wed Aug 10, 2011 12:42 pm
I assume you mean beaded? as in glass bead blasted..?
If you want a professional finish buy a metal polishing kit with the correct pumice compunds and jewelers rouge... thats if you want it to look professional.
I would also check very carefully why LAT valve covers have their ribs removed at the rear vs normal ford cast alloy rocker covers... check your firewall clearence.
Post by gtsmrt » Wed Aug 10, 2011 2:21 pm
Yes I did mean glass beaded. I'll look up a metal polishing kit as I want it looking professional (or as close as I can get it). Thanks for the comments.
Post by gtsmrt » Sat Aug 20, 2011 12:30 pm
My first go at metal polishing went surprisingly well. I purchased a polishing kit and following tips that I received, managed to achieve a very shiny and almost mirror like finish.
Thanks, Robin.
