Mallory Ignition Coils
Posted: Tue Aug 02, 2011 12:54 pm
There is often confusion about ignition coils for the Tiger.
(BY part numbers refer to Real Steel online catalogue Section 9, page 5).
Mallory electronic distributors (magnetic and unilite) use Mallory ignition coil BY29216.
This coil must use a Mallory ballast resistor (resistance 0.75-1.50 ohms) BY700 or similar.
There is another Mallory coil 29219 (RS do not appear to stock this) which does NOT need a ballast resistor.
Summit Racing pages:
http://www.summitracing.com/parts/MAA-29216/
http://www.summitracing.com/parts/MAA-700/
http://www.summitracing.com/parts/MAA-29219/
RS also stock a universal coil for a points distributor BYD500-J which must use a ballast resistor BYRU 10 or similar.
***None of the above are to be used with capacitive discharge or MSD ignition systems.
