slave cylinder pushrod
Post by ksherlock » Thu Jun 30, 2011 10:11 am
After replacing the original 3 finger clutch I found that there was not enough adjustment on the pushrod to get the correct clearance. I think this is because the new diaphram clutch is a slightly lower height. I made a longer pushrod to overcome the problem. Has anyone else come across the same problem?
Post by Mal » Thu Jun 30, 2011 10:33 am
When I first bought my tiger it had the same problem, even though it still had the three finger clutch. It was resolved by the same means as you have done there. I also had the same on a Hillman when I replaced the clutch. Fixed the problem the same way.
Post by gtsmrt » Thu Jun 30, 2011 12:17 pm
This is not a problem with the slave cylinder is it? I ask this because I need to replace my slave cylinder soon.
Thank you, Robin.
Post by bigbob » Thu Jun 30, 2011 1:49 pm
I used a slave cylinder from Rover 620 that is smaller bore & gave more travel.
Post by V8 burble » Thu Jun 30, 2011 2:10 pm
Bob,
Any chance of a part number for that 620 slave cylinder?
Post by gtsmrt » Fri Jul 01, 2011 9:02 am
Probably not the same part number, but mine was a P5576 (Protex brand).
Post by garyv8tiger » Fri Jul 01, 2011 8:38 pm
mines off a merc sprinter from mcgee motor sports woodhouse :mrgreen:
Post by gtsmrt » Thu Jul 28, 2011 1:02 pm
I would like re-open this post by asking a question regarding the slave cylinder push-rod. I have recently replaced my slave cylinder and noticed in the WSM that the push-rod has a retaining clip to hold the push-rod in position on the clutch release lever. My setup has a rubber boot over the release lever, but no retaining clip that I can see. Is this the same as other forum members Tiger's or does it sound like my clip is missing? If it does require a clip, are they still available?
Thank you, Robin.
Post by Mal » Fri Jul 29, 2011 6:18 am
Robin, i don't have a clip on mine, but there is a groove in the nut end of the push rod which could be there to locate a clip. I would take a pic but i don't have my camera at home.
Post by V8 burble » Fri Jul 29, 2011 7:24 am
See Workshop Manual:
Section D (Clutch & Propshaft), page 7, part number 29.
Post by gtsmrt » Fri Jul 29, 2011 9:37 am
Thanks for the replies gents. Mine also has the groove in the rod Mal... Maybe over the years they have a tendency of breaking or falling off? V8burble... that was the diagram I was looking at which seems to be absent from mine. So does anyone know if they are still available?
Thanks again, Robin.
Post by gtsmrt » Sat Jul 30, 2011 12:53 am
I was doing a bit of searching around and found a retaining clip listed on a few Tiger part sellers. Is this a replacement for the original clip or is it for something else? Here is a link on the Sunbeam spares site: http://www.thesunbeamsparescompany.co.uk/ In the catalogue section under 'Tiger Clutch', part TT02.
Thanks, Robin
Post by V8 burble » Sat Jul 30, 2011 8:14 am
TT02 is the retaining clip for the clutch fork.
It is unlikely that the clip you require is still available, but I am open to contradiction.
I have a feeling that the clutch pushrod will function perfectly well without this clip.
Post by gtsmrt » Sat Jul 30, 2011 9:26 am
V8 burble wrote:TT02 is the retaining clip for the clutch fork.
Thanks for the reply, but I was kind of hoping that it was for the rod. We will see if anyone else has any input though. I took my Tiger around the block today and everything seems to be working just fine with no leaks any more. :)
66str1
another route
Post by 66str1 » Fri Aug 05, 2011 2:27 pm
another route... I put a CNC slave cylinder with a wilwood clutch master clyinder. I had to fabricate a braket to work with my scatter sheild. It works reaally well with my 10 1/2 centerforce dual friction clutch. cnc part $53 US and master $65US,braided line $35. 2x3 1/4 inch steel angle to fab braket
