Hi can any one help just need to know , is the fuel line fixed to the bulkhead just after it goes from the flexi to the steel pipe, or not fixed at all ,its just my one has a bracket floating about down there, just trying to get some jobs done before i start using it.
cheers paul
fuel line
fuel line
Hi Paul,
The fuel line is fastened to the body upto the flexy then it crosses to the side of the gearbox..there are 2 brackets that hold the front half of the fuel line to the engine.. 1 with a rubber grommet that secures the bottom bolt of the starter motor the second has a clamp on it and secures to the block just below the dynamo(alty) bracket..
hope this helps..
hope this helps..
