Hi
I have my heads off my car and the code is C40E i just want to know is this correct does anyone have any clues, its a 65 mk1a, also want to know how the fuel pipe runs under the bonnet what side it comes up
cheers paul.
Heads casting no
Hi Paul,
I'm not sure about the head code numbers, but the fuel line runs along the chassis on the right-hand (driver's) side. It has a flexible join where it comes off the chassis and has a clamp that bolts on to the engine block running up in front of the generator bracket and dip stick.
Hope this helps.
Hope this helps.
Hi Paul, here's a link that Graham kindly sent to me a while back.
I thought it may help with the number.
http://mustangtek.com/block/Block.html
casting no
Hi
thanks for that in that link is said heads off a 289 ?
not sure now just wanted to make sure there 260 heads
cheers paul
cheers paul
casting no
Hi
If they are 289 heads i am ok with that, I will put some pictures on the site when i get them back from the engineering shop , they need a bit of work as had a head gasket gone.
cheers paul
cheers paul
