Performer rpm intake
Will a edelbrock performer rpm intake, holley carb and low height air cleaner fit under the bonnet of a Tiger
The F4B manifold offered in the LAT options was a high-rise manifold, but I'm not sure what height it is. I would think it would be similar to the performer RPM manifold, so should fit under the bonnet. Just double check your heights before committing to anything.
Thanks Michael & Robin.
The engine was built with the performer rpm intake instead of the lower performer. I was a bit concernd as I thought it was going to have the performer. I had a quick measure up, which was not perfectly accurate as the cowl panels are not on the car yet, and it was not looking promising.
Things are now looking positive.
cheers mal
cheers mal
