Limited Slip Differential (Winter project)
Twiddling your thumbs?
Need a winter project?
How about fitting a LSD in your Salisbury 4HA axle?
In my opinion a limited slip differential should have been fitted at the factory to every new Tiger as standard. Obviously cost considerations ruled out this important safety item.
There are basically three different types of LSD:
1)clutch plate (Thornton Powr-Lok)
2)geared or torque-biasing (Quaife, Torson-Gleason)
3)viscous.
I advise using the Quaife ATB Helical gear type, not the clutch type (Powr-Lok) which is generally fitted to the Tiger.
The Quaife LSD is far smoother in engagement than the Powr-Lok, which tends to snatch. This snatching can further aggravate an already potentially hazardous situation.
For further information on the Quaife LSD visit:
www.quaife.co.uk
Revised link for QDF1W lsd:
http://www.quaife.co.uk/shop/search/res ... C214%2C215
Quaife Engineering: Telephone 01732 741144
You will need a specialist company to install the Quaife LSD and I can recommend Competition Transmission Services (The Gearbox Man) who has a “supply and fit” service:
http://www.gearboxman.co.uk/
Telephone: 01582 840008 (Speak to Bernie, the owner)
The axle should be supplied bare without the half-shafts. Additional labour costs will be charged to remove the hubs and half-shafts.
Current pricing (excluding vat) on the LSD is £775. The fitting charge is £180 plus the price of replacement parts as required. A new pinion bearing and oil seal will be routinely fitted along with any other bearings, spacers etc.
I would estimate the total cost to be about £1200 (including vat).
Note that the Quaife LSD uses standard EP90 oil such as Comma's EP90W GL-5:
http://www.commaoil.com/productsguide/view/6/186
In contrast, the Powr-Lok requires special oil, such as Morris Lubricants' XEP90, which contains a friction modifier.
http://www.morrislubricantsonline.co.uk ... product=35
Whilst the axle is off the car it may be a good idea to replace the propshaft universal joints if you are unsure about their condition.
To make the difficult job of rear hub removal somewhat easier, I suggest you have a special puller made as per this article by Dan Walters:
http://www.tigersunited.com/techtips/Wa ... uller1.asp
Before using the puller, make sure that the hub nut is reversed on the shaft (castellations facing inwards) and is flush with end of the shaft. A sturdy piece of wood may be placed between the nut and the underside of the top half of the puller. This, hopefully, will lessen the chances of doing serious damage to the thread on the shaft.
3)viscous.
www.quaife.co.uk
Brilliant article V8 Burble, perhaps this could be reprinted with your permission as an article for the club magazine, Cats Whiskers (for the benefit of our non www members)
I must admit, I have no technical knowledge of the LSD units that can be fitted to the Tiger, or indeed which one I have but I will agree with you they should be standard as they make a huge difference. Both from getting the power down in a straight line from a standing start and also from keeping the rear end in check when cornering hard.
I wonder what setup the racing boys use on the circuits.
Would be good to hear what Tiger owners are running/have used and your article has educated me to find out what system I am running, even so am very pleased with the results and would encourage owners even just for the safety argument (better roadholding/accelerate out of trouble) to consider installing a system.
Only thing I would also consider, if one is thinking of drag-strip type standing starts, then anti-tramp bars are a must.
Thanks again.....
Thanks again.....
Just adding an update from the “Transmission Oils-Warning” thread.
The Thornton Powr Lok LSD requires a special EP90 oil containing a friction modifier.
This one from Morris Lubricants (XEP90) appears to be generally available and at a reasonable price.
NB The Quaife LSD uses standard EP90 without the friction modifier.
Tony,Tomaselli wrote: they should be standard as they make a huge difference. Both from getting the power down in a straight line from a standing start and also from keeping the rear end in check when cornering hard.
Thanks again.....
Different types of LSD's work in different ways.. and clutch pack setups like the posi's can have hard or soft clutch packs which contorls how aggresively thre LSD comes into play.. I have found the LSd in the Tiger great in the dry.. but in the wet it makes the car a handful.. when the diff locks up it can snatch the back quite quickly... on slipery winding wet roads can be a handful.
It's not that your crap, you just need more practice... As they say, practice makes perfectbigbob wrote:I have salisbury LSD in mine, which I think is set up too harsh. I too find that whilst traction off the line is great, the rear end snaps round far too quick, or maybe I'm a crap driver & cant hold a drift.
Robin,
Quaife's website has been changed with the result that the link (just revised) in my original post no longer works.
Quaife definitely does do a LSD (part number QDF1W) for the Tiger/Jaguar 4HA axle and here is the new link:
Hi,V8 burble wrote:Robin,
Thank you for the link and the part number.
