Hi I am currently working on a tiger for a friend who uses it for classic motorsport in europe.
With high temperatures and the tigers poor cooling system I am going to have to do a few mods.
We have already fitted an alloy rad setup and spaced the hood up at the rear to let air flow through the engine bay altough I would like to fit cooling vents in the fenders/wings as were fitted to classic works tigers.
I was wondering if anyone could shed any light on this. Has anyone ever done this before. Can i buy a ready formed tube to join the inner to the outer fender to make it look as neat as possible.
Andy
Air vents in wings/fenders
Andy,
There are a few different vents on the Tigers. The works rally cars had the triangular vents high up on the wings, the US based race cars had vents in the sides lower and larger.. and there were optional LAT vents for the sides that someone in the USA is reproduicing right now. some examples are:
Works rally:
www(dot)sunbeamtiger(dot)co(dot)uk/40anniversary_files/adu312b(dot)jpg
Hollywood sports cars tiger:
www(dot)dalesresto(dot)com/hollytiger5a(dot)jpg
www(dot)dalesresto(dot)com/hollytiger41d(dot)jpg
LAT:
go to webshots(dot)com and look for photos:
2181024240054462410oTDFWO
2723575950054462410KSnHVC
replace (dot) with .
Works rally:
LAT:
Andy,
I used to have the back of the bonnet propped up until someone pointed out the huge air pressure build-up in front of the windscreen at speeds above 30mph...Try the old trick of pieces of string taped along the back of the bonnet on the motorway - they're sucked into the engine bay above 30, you're actually reducing airflow through your rad.. So I blocked up the back, allowing air only to escape at the sides - big improvement. After a race the tops of the wings are almost too hot to touch, and I've never overheated even at high ambient temperates with a normal steel rad. Admittedly my engine is not particularly hot.
I trust you've also blocked up the holes in the rad bulkhead either side of the rad to ensure all the air goes through it. (Or, before Simon James chips in, you could graft an Alpine Mk2 front end on which doesn't have those holes...
Good luck, Andrew
Good luck, Andrew
