Stalling Problem
Posted: Mon Sep 20, 2021 1:56 pm
Hi All
Can anyone offer advice on a couple of annoying problems with my Tiger.
It is standard apart from being fitted with Electronic Ignition and a 2 Barrell Holley Carburettor.
I'm experiencing occasional stalling when I pull up to junctions, the tick-over slumps and the car stalls, it immediately restarts again and with a bit of revving will tick over. it seems worse when cold or when fully warmed up but only does it intermittently when hot.
I have also noticed a slight hesitation/stuttering when on very light throttle settings, as if the mixture is maybe too weak.
The car however accelerates smoothly with no hesitation or miss firing and when cruising on part throttle it's fine.
I have recently rebuilt the Carburettor after some flooding issues and have double checked the float height which is set as per the Holley instructions, I've not adjusted anything else, I'm thinking its a carb issue but anyone else offer any words of wisdom?
