Standard air filter replacement filter element
Shindles
Post by Shindles » Thu Nov 28, 2019 12:37 pm
Is there a more efficient filter element for the standard oval Tiger filter?
Re: Standard air filter replacement filter element
Post by garyf » Thu Nov 28, 2019 3:17 pm
Mines got a K&N Filter fitted in the original AC Filter Housing.
This was installed by the previous owner and I have no Idea if it is more efficient than a standard one, although K&N are a well known performance upgrade manufacturer?
Post by bigbob » Thu Nov 28, 2019 4:05 pm
K&N are meant to be the best. Can be cleaned and reused. Avoid after market foam ones as they have been known to catch fire when carb spits back.
Shindles
Post by Shindles » Thu Mar 12, 2020 11:08 pm
Managed to fit a 2" K&N filter. Just sufficient clearnce under the bonnet if you chop off some of the bolt.
Rolling road dyno showed a 3bhp increase in power.
jerryg
Post by jerryg » Wed Mar 18, 2020 8:51 pm
I'm sure I have a KN element in mine. What is the recommended cleaning chemical for it please and by memory, are you not supposed to spray the element afterwards with an oil. Next question- if this is correct, how viscous an oil?
Post by garyf » Thu Mar 19, 2020 11:57 am
Jerry
K&N Do a Kit for Cleaning & Re-treating their Air Filters as the link below:-
https://www.googleadservices.com/pagead ... hA8&adurl=
jerryg
Post by jerryg » Sat Mar 21, 2020 6:17 pm
Thanks Gary.
