oil filter pipe
ksherlock
oil filter pipe
Post by ksherlock » Sun May 28, 2017 5:06 pm
Is there a recommended position for the curved pipe on the oil filter assembly? Mine is between the oil filter and the water pump but on my first tiger back in 1969 I am sure that it was between the oil filter and the header tank. At the moment the rubber part of the pipe is only about 10mm from the fan which is a bit worrying.
Post by martin172 » Sun May 28, 2017 7:10 pm
I suspect that the standard position for the hose was between the filter and water pump, possibly to keep it out of the way of the steering column on LHD cars.
I have mine between the filter and the header tank to keep it away from that pesky fan.
I think peace of mind plays a bigger part in the fitting of things like this than correct does.
ksherlock
Post by ksherlock » Mon May 29, 2017 10:48 am
Thanks. I will change the position. Yours looks like a new pipe.
Post by martin172 » Mon May 29, 2017 11:34 am
Yeah, they are new.
The old ones were knackered so I got a new set from Sunbeam Spares.
Not cheap but very good quality so should last for a long time.
