s2mpf
by s2mpf » Wed May 03, 2017 9:09 pm
Who makes the most efficient (biggest) radiator? I have alloy rad but still running at 95 deg C
by bigbob » Fri May 05, 2017 3:41 pm
That should work ok. I'd check thermostat. or water pump. Also sender can read wrong. Try infra red temp probe to double check.
tigertim
by tigertim » Fri May 05, 2017 4:03 pm
If you still have the original. Get it re cored with 143 cores up from the original 90 can't get mine hot.
