Fan Belt
Fan Belt
Post by martin172 » Tue Jan 03, 2017 10:56 pm
Hi, I'm in need of a new fan belt.
Can anyone point me in the direction of a make and part number that is the correct size.
I assume that no-one makes one specifically for the tiger anymore.
Thanks.
It's a standard 260 layout with generator btw.
tgr747
Post by tgr747 » Wed Jan 04, 2017 8:36 pm
hi martin,you should be able to buy one at any local store,if not they will order one for you.if I remember rightly you want a 1275mm long by 10mm,take your old one with you and compare them.
Post by martin172 » Wed Jan 04, 2017 9:34 pm
Thank you Brian.
Hope you are well.
