Change oil inlet manifold
Guys can I get away without changing the oil if I swap inlet manifolds? I've just changed the oil but now decided to fit my f4b instead of having that silly street master high riser
Sounds good, last time I had the manifold off though there was some risidual water that dripp into the valley when I lifted it off' I don't know if it's anything to worry about or whether there is a way of removing all water before lifting it off. Changing the oil or even draining oil before removal isn't really mentioned often on other sites
