replacing front bush in rear springs
Can anyone supply or point me in the right direction to source a short length of pipe, 47mm or 1.27/32" in outside diameter. I need to replace the large bushes in the front of the rear springs.
Try to use a large socket and have the spring blocked in the press,
If the bush removes to easily then the new one will not be gripped by the spring and the eye is to large,the spring will then rotate on the bush which has an eccentric hole for spring camber and height.
rear spring bush
I understood that new bushes do not have the eccentric hole.
Re: rear spring bush
Some do, some don't.ksherlock wrote:I understood that new bushes do not have the eccentric hole.
Sunbeam Specialties ones are eccentric so they are available.
