by Mal » Thu Oct 29, 2015 7:32 am
I am about to replace the exhaust on the car.
Since the tail pipes go under the rear axle, How much clearance do I need. I can go by the old system but I would like to have it closer if possible
Just wondering what clearance others have.
V Mad
by V Mad » Sat Nov 28, 2015 8:07 am
Jack up the car at the rear allowing the wheels to fully drop. Then measure the lowest axle position. I would use that as the highest point where the exhaust should run under the axle.
