Gearbox Noise
Posted: Sun Jul 26, 2015 12:15 am
There is a rattling/buzzing noise coming from the gearbox of my Tiger. Sometimes it is worse than others, and driving conditions don’t seem to make any difference to the severity; sometimes it‘s bad, sometimes it‘s not. It is also reluctant to engage any forward gears when coming out of reverse, and this fault appears to be getting worse/happening more often. I suspect a linkage problem rather than actual gearbox, but could it be anything more sinister with the box?
The clutch is only a few thousand miles old and the master & slave cylinders are new.
If it is a linkage problem, can I remove the linkage without removing the gearbox from the car, and are spares available in the UK?
