Fed up with dodgy nipples??Seen these in the press. Available in imperial as well to suit older cars. Looks a good upgrade.
STAINLESS NIPPLES
Hosetechnik, the performance braking division of Forge Motorsport, has released a brilliantly simple, yet incredibly effective new product; stainless steel brake bleed nipples.
The firm has engineered the product from aerospace-grade material after receiving an overwhelming number of requests to create a ‘fit and forget’ solution that could be used to replace the OEM parts on most modern brake callipers. On many European cars however, these applications can go back as far as the ‘Seventies and beyond.
Each pack contains four 10.1mm nipples, which can be used to upgrade almost any reasonably modern car, preventing the future possibility of corrosion (and the subsequent sheering-off scenario nightmare), and making fluid changes and bleed-through procedures a total doddle. As with all Hosetechnik braking products, these come with a lifetime guarantee.
Web: www.hosetechnik.com
Tel: 0845 838 5364
Price: £19.94
