Clutch master cylinder bore
Post by tigerman7347 » Sat Mar 15, 2014 11:11 pm
Can anyone tell me the bore of the clutch master cylinder?
Cheers Rob
redbaron
clutch master cylinder bore
Post by redbaron » Sun Mar 16, 2014 12:09 am
Hi Rob,
Clutch master cyl is 5/8" or .625
Girling cyls are readily avaliable new,from the usual suppliers,if re sealing an old cyl,may not be cost effective as piston will score bore over time.
Post by martin172 » Sun Mar 16, 2014 10:21 am
Hi David,
who are the usual suppliers as one of these is on my shopping list at some point.
Mine has died due to a nest of corrosion pitting.
Master cylider clutch
Post by tigerman7347 » Sun Mar 16, 2014 9:13 pm
Thanks Red baron. I thought they were 0.75 inch? Or is that too big? I think I may have a clutch that is too heavy.
Rob
Post by tigerman7347 » Sun Mar 16, 2014 9:47 pm
Sorry, basically I am asking because I have a new one with 3/4" bore. Is this ok to use?
redbaron
Post by redbaron » Sun Mar 16, 2014 10:39 pm
Hi Rob,
you can use the 0.75 or 3/4" clutch master cyl,what you will have is a heavier feel as you are trying to push more fluid,it will alter the "bite point".
The 5/8" cyl works fine,without giving to much of a heavy feel.
Do know what clutch you have fitted ?,even very heavy clutch covers will operate with these cyls,at the expense of a short life for the seals.
David
Re: clutch master cylinder bore
Post by tigerman7347 » Sun Mar 16, 2014 11:14 pm
redbaron wrote:Hi Rob,
David
Thanks David
