vented front disc and steering rack
paulw
Post by paulw » Thu Mar 06, 2014 5:36 pm
Hi my car needs all new front brakes and was thinking of going for vented disc types any info on the way to convert would be very helpful and also my steering rack is not good so needs replacing again any help please
Thanks Paul
Post by Mal » Fri Mar 07, 2014 5:41 am
Paul
There was quite a lot of discussion here on the Brembo brake thread http://sunbeamtiger.co.uk/forum/viewtop ... ght=brembo
Willwood also make a kit now for the Tiger. If you go to their webb site you should find all the info needed. Probably not a lot more expensive than the used Brembo set up due to the machine work needed.
With the steering rack there were some new ones built over there to the standard Tiger specs'.
Then there is the midget rack conversion which Dean had kits for.
You can also use a Mazda mx5 rack if you want to go power steering, or you could turn it into a manual rack if you didn't want a power rack.
I have just converted my Tiger with a mx5 rack and love it.
Sounds like you have been having trouble with steering racks ?.
paulw
Post by paulw » Fri Mar 07, 2014 12:37 pm
Hi yes trying to rebuild front suspension and brakes and rack etc yes I was thinking of the wilwood brake conversion so I will email them to find out if there is a stockist in the UK , with the steering rack very mixed messages from sunbeam spares companys so don't know do like the idea of mg rack don't know who does it over here my old one is ford I think
Thanks Paul
dpuzey
Post by dpuzey » Fri Mar 07, 2014 5:33 pm
Hi Paul, you might want to have a read of the 'Classic Motorsorts' magazine Tiger restoration. They originally fitted a Midget rack but went back to standard, they also fitted Willwood front brakes.
As an alternative you might want to give Hi Spec in Dartford Kent a ring, as they are in the process of making a kit of parts to fit 4 piston aluminium calipers and 260mm diameter vented discs, should be finished in a couple of weeks.
Dave Puzey
1965 Midnight Blue Tiger
1958 Speedwell Blue Sprite
1967 Mid Grey SWB Land Rover
2011 Scuba Ford KA
Used to own 1985 Targa Red Rover 3500 TP Vitesse
Post by Tomaselli » Fri Mar 07, 2014 9:09 pm
Certainly would recommend 4 pot calipers with vented discs. The stock setup is woefully inadequate for today's traffic. Can't believe I once visited the Nurburgring with standard barkes, that was pitiful! Quite a few companies now do aftermarket brakes, no kits though specific to the Tiger so some 'adjustment' needed to make it all work.
I hear from David Herning Motorsport that Burton Power do very attractive priced aluminium 4 pot calipers, from the MK2 Escort me thinks.
Quick rack from the early MG Midget/Sprite is a fab conversion, that married to power steering is an awesome combination - highly recommend it! :mrgreen:
paulw
Post by paulw » Fri Mar 07, 2014 10:07 pm
Hi and thanks for your replies I will give the place a ring in Kent and also its worth giving Dave herning a ring his place is only 20 mins from me and with the rack I may try and find a original as not sure about mg type , would be nice to get out in the car again as been sitting for 2 years .
Many thanks Paul
Post by Tomaselli » Fri Mar 07, 2014 10:28 pm
Paul, don't forget if you decide to run with bigger calipers and discs then you'll need larger alloys, 15 inch usually does the job.
paulw
Post by paulw » Sat Mar 08, 2014 8:29 am
Hi
Yes got the 15 inch wheels that was one of the first things I done it did not look right with the wheels it had on it .
Thanks now armed with some info , I looked at the dales wilwood set up looks good but very expensive plus got to get it here don't know how I would explain that to the wife .
Post by meadowhog » Sun Mar 16, 2014 11:00 pm
If Peugot 406 fit then would these fit too?
http://www.ebay.co.uk/itm/Brembo-4-pot- ... 2c7b97cf50
paulw
Post by paulw » Fri Mar 21, 2014 11:43 pm
Hi fitting them brembo parts looks like a fair bit of work not sure about the brembo brakes I let you know what I fit cheers
H, Sunny 65
Post by H, Sunny 65 » Sat Mar 22, 2014 10:27 am
No the Alfa Brembo caliper is 100mm between centre's for mounting bolt's. Where the Peugeot brembo's are 85mm same as all early Girling caliper's.
Willwood do a kit for the tiger, part number 140-11743 it includes hub's. I was quoted £900.00 + vat http://www.wilwood.com/Pdf/howtostories ... nstall.pdf
Post by meadowhog » Sun Apr 27, 2014 1:50 pm
I just bought a pair of vented 406 coupe discs from Euro car parts for £30. Got the MGB arms for £10 off eBay. Only looking for an early rack and calipers now.
