water pump
water pump
Post by ksherlock » Wed May 15, 2013 11:41 am
Has any tiger owner ever changed the water pump with the fan still attatched? On my current tiger there is not enough clearance to remove the fan without first removing the radiator. On my first tiger back in 1970 I could remove the fan with the radiator still in position. The water pump in that instance was the original so maybe later pumps have a longer shaft. thus reducing the gap between the radiator and the end of the shaft.
