engine earth strap
engine earth strap
The engine earth strap on my car is attached on one end to the front bolt of the L/H exhaust manifold and on the other end to one of the bolts on the lower end of the left hand bracing rod . Is this the correct location for the earth strap ?
engine earth strap
The earth strap is bolted to one of the redundent Alpine gearbox crossmember bolts,5/16ths unf, and the other end is located on the clutch slave cyl mtg bolts,for the slave cyl.
