Where does the the speedo cable come through the firewall on a RHD car.
I can't remember.
Thanks Mal
Speedo cable
Speedo cable
Hi Mal, I have been having problems with the inner cable, having to change once a year because there is so much heat coming from the engine it drys the cable out, then the speedo doesn't run true. I have now fed the cable inside the cab via the false plate, you wouldn't know it was there.
Rob
Rob
