windscreen frame to body rubber
Just in the process of changing screen rubber and body to frame rubber.
Looking for advice on rubber wedges. At what stage do they go in, between which part of the body to frame rubber?
Thanks Jay.
Thanks Jay.
Hi Jay
I can't answer your question but maybe some of these 'Tech Tips' might help! No bulls eye but may be useful.
http://www.team.net/html/tigers/1999-11/msg00325.html
http://www.team.net/html/tigers/1996-07/msg00344.html
http://www.team.net/html/tigers/1996-07/msg00338.html
http://www.team.net/html/tigers/2000-06/msg00067.html
http://www.team.net/html/tigers/2000-03/msg00345.html
http://www.team.net/html/tigers/2009-07/msg00136.html
http://www.team.net/html/tigers/2009-07/msg00132.html
Thanks Graham it looks like i'm on the right track I knew this would be a job that was going to give me a head ache it would seem the last bit of putting the completed window back on the car is down to trial and error and every car will be different.
Still would be nice to hear from someone who has done it
I haven't put mine back on the car yet but I made the vid to remind me when I did.
It was taken off a couple of years ago and my memory is poor hence the vid.
You can have a look at the vid if you like which shows it just after I had removed the windscreen frame with the rubber seal attached to it but I will have to load it onto photobucket but you must promise not to laugh at my Tommy Cooper impersonation.
Alternatively, you could wait for a specialist to give you a definitive answer.
