Shifter dismantle
Shifter dismantle
Post by Mal » Sat Aug 18, 2012 4:55 am
Anyone stripped down a shifter for a re-chrome. Is the reverse lock out lever supposed to slide out first to dismantle it or is there some other trick to peform first.
dpuzey
Post by dpuzey » Sat Aug 18, 2012 4:22 pm
You need to unbraze the piece at the bottom of the shifter that lifts up when you pull the tee bar, then knock out the wire and then the tee bar will come out.
There is a spring inside to retrieve as well.
Dave
Dave Puzey
1965 Midnight Blue Tiger
1967 Mid Grey SWB Land Rover
Used to own 1985 Targa Red Rover 3500 TP Vitesse
Post by Mal » Sat Aug 18, 2012 9:00 pm
Thanks for the reply Dave.
bernd_st
Post by bernd_st » Mon Sep 03, 2012 10:00 pm
Didn't believe it myself but you can leave the plasticbush in place for the rechrome. It works...
