Car won't start and fitting anti tramp bars
marinerblueuk
Post by marinerblueuk » Wed May 30, 2012 10:50 am
Help needed!
1. After running perfectly when I tried to start the car at the weekend (hot start) it wouldn't fire. After checking fuel and sparks discovered no spark from the coil lead.. It has had new Pertronix ignitor ignition and Flamethrower coil installed a few weeks ago and has been running perfectly.Any advice on how to narrow down the problem? I know that if either gnition or coil is faulty then it will be replaced but how do I know which one it is? I don't want to replace parts that are working. And is the failure just bad luck? I thought this combination would be very reliable.
2. And the 2nd question is how do you fit bot on anti tramp bars? Looking at the pictures I can see that one end bolts on to the U bolt but where does the other end go?
