door handle
door handle
Post by ksherlock » Sat Feb 18, 2012 12:01 pm
I need to remove the exterior door handles. I have removed the spring clip on the connecting link but the link does not seem to want to come out of the inner end of the lock. Should it just pull out?
Post by V8 burble » Sat Feb 18, 2012 12:35 pm
The exterior handle is held by a nut at the front and a screw at the back.
Post by Tomaselli » Sat Feb 18, 2012 5:17 pm
To save starting a new thread;
ksherlock wrote:I know that the door handle is attached to the door by a nut and a screw but it is also connected to the door lock by a short link inside the door. It is this link that I am having difficulty disconnecting. I have removed the spring clip but the link does not seem to come out of the inner end of the barrel that the key operates. I am reluctant to use too much force in case damage occurs
