Hi all,
My car is fitted with Minilite type alloy wheels, all with the same offset.
Whilst looking great on the front, the rear looks anorexic .
Does anybody know of a source of wheel spacers, possibly about an inch, thick. Ideally the bolt on ones would be great so as not to have to remove the hubs/halfshafts to fit long wheel studs.
Rich
Rear Wheel spacers
It is easy to change to longer studs if you drill a 3/4" hole in the brake back plate in line with studs. Can then change studs without pulling 1/2 shafts etc.
Or if you use a spacer with sleeved wheel nuts, then keep existing studs.Make sure that nuts wind on enough, but don't bottom out without fully tightening.
