Brake light switch issues.
Post by gtsmrt » Sat Nov 26, 2011 10:57 am
Just wondering if anyone has experienced their brake lights coming on after running for a while. I was checking some things while the Tiger was idling and noticed that the brake light were staying on. They were OK when I first started the engine, so it is fair to say that the issue is heat related. Is this due to brake adjustment or purely heat?
Your help would be appreciated.
Thanks, Robin.
Post by gtsmrt » Sun Nov 27, 2011 8:11 am
Looks like I am going to have to change my stop light switch, but if I remember correctly the new style switches available aren't very reliable. Does anyone know which ones to stay clear of?
Thanks, Robin.
alpine5gt
Post by alpine5gt » Sun Nov 27, 2011 10:54 am
There is a chap on the CAT site selling modern replacements that work off the brake pedal. May help
Post by gtsmrt » Sun Nov 27, 2011 11:30 am
alpine5gt wrote:There is a chap on the CAT site selling modern replacements that work off the brake pedal. May help
Thanks for the post. A mechanical switch off the peddle would definitely be an option.
Post by garyv8tiger » Fri Dec 02, 2011 8:40 pm
lucas spb 401 available on ebay cheap .just fitted one and it works
Post by gtsmrt » Sat Dec 03, 2011 5:25 am
garyv8tiger wrote:lucas spb 401 available on ebay cheap .just fitted one and it works
Thanks Gary, will check it out.
Post by gtsmrt » Sat Dec 03, 2011 10:58 am
Hi Gary,
I checked it out on Ebay and I will probably order one soon. I have never replaced the brake switch before and was wondering if you need to bleed the system after replacing?
Thanks, Robin.
Post by garyv8tiger » Sat Dec 03, 2011 4:46 pm
have someone there to help undo the old one and remove put a finger over the hole to stop fluid coming out ,give the old one to the person helping to take the washer off the old one and put it on the new one and screw it back in ,i never bled mine but it appears ok.dont get fluid on paint put a cloth under switch
Post by gtsmrt » Sat Dec 03, 2011 9:15 pm
Thanks for the advice Gary.
Twin Turbo Tiger
Post by Twin Turbo Tiger » Sat Dec 17, 2011 4:31 am
I just use from a 65 ford falcon and have never had to bleed the brakes
