Brake light switch issues.
Just wondering if anyone has experienced their brake lights coming on after running for a while. I was checking some things while the Tiger was idling and noticed that the brake light were staying on. They were OK when I first started the engine, so it is fair to say that the issue is heat related. Is this due to brake adjustment or purely heat?
Your help would be appreciated.
Thanks, Robin.
Thanks, Robin.
Hi Gary,garyv8tiger wrote:lucas spb 401 available on ebay cheap .just fitted one and it works
I checked it out on Ebay and I will probably order one soon. I have never replaced the brake switch before and was wondering if you need to bleed the system after replacing?
Thanks, Robin.
have someone there to help undo the old one and remove put a finger over the hole to stop fluid coming out ,give the old one to the person helping to take the washer off the old one and put it on the new one and screw it back in ,i never bled mine but it appears ok.dont get fluid on paint put a cloth under switch
