TXJ7
by TXJ7 » Tue Feb 14, 2012 9:28 pm
Photos of my installation. I remember more details. Disc machined down to 280mm dia, mounting holes re-drilled in disc using original as template.Centre hole eased slightly. Back of hub had 3mm removed so disc was in correct alignment to caliper. Steering arm packed off with washers & trackrod end adjusted to suit. I went up 1/8th inch on master cylinder bore to reduce padal pressure, but I don't use a servo.[/quote]
Hi Bob, I've machined some spacers so can leave the hubs as original (and then reversed the disc to fit):
Spacers are 14.5mm thick drilled to take 4 x 3/8 countersunk bolts to the hub and then same again for the disc to the spacer ( c/sunk to maximise clearance on the back of disc to the upright ).
I have some basic drawings and other measurements if anyone is interested.
cheers,
Stuart
Tiger Mk1 (289)
Jag 3.4 Mk2 (rusty!)
Cortina Mk1 Estate (302)
by bigbob » Wed Feb 15, 2012 1:17 pm
Can't quite picture what it looks like, have you photos of it fully assembled?
Has it widened front track? What discs are those?
Seems a neat solution.
TXJ7
by TXJ7 » Wed Feb 15, 2012 8:33 pm
Track is standard, hubs are not modified in any way.
Discs are the usual Pug 406 reduced to 276mm dia and a couple of extra holes drilled to attach to spacer
MGB arms are ready to fit along with Dean's suggested LVD rod-ends for clearance to the disc
MG sprite rack is ready (awaiting paint but th garage is too cold!) with the Dean's LHT / RHT adjusters and clamps
In the meantime, engine will be out soon to fix the blown LH headgassket (Pyrenes trip didn't help that!), sort-out the 10yr old rear crank seal oil leak (!) and sort out the gearbox linkages and change the clutch!
Tiger Mk1 (289)
by Brad1380 » Sat Feb 18, 2012 5:51 pm
[quote=
cheers,
Stuart[/quote]
Interested in seeing the drawings.
cheers
Brad
by V8 burble » Sun Mar 11, 2012 7:58 pm
What is the minimum wheel size for Brembo caliper clearance?
Is any particular offset needed to avoid tyres rubbing on wheel arches front and rear?
Tyre size?
Any further detailed info would be greatly appreciated.
Many thanks.
by garyv8tiger » Sun Mar 11, 2012 11:11 pm
i think its 14 inch .i,m sure tomasellie has 14 inch on his .i use 16inch
by Tomaselli » Sun Mar 11, 2012 11:54 pm
15 inch on my current alloys, I suppose it will depend on the offset and casting/clearance of the alloy wheel, but you might just squeeze in 14 inch. I have another set of 15 inch alloys which I bought from one of the racing boys and know that the clearance on them are much greater as the 'profile' of the circumference is much shallower.
by V8 burble » Mon Mar 12, 2012 8:09 am
Has anybody successfully fitted 14 inch wheels with Brembo calipers?
If so, what offset etc is required to avoid touching front and rear arches?
I am assuming that 15 inch wheels/tyres will cause the above fouling problems on standard arches.
Is that correct?
by gtsmrt » Mon Mar 12, 2012 8:21 am
V8 burble wrote:Has anybody successfully fitted 14 inch wheels with Brembo calipers?
Is that correct?
I am believe Dales in the US sells a Wilwood setup which is compatible with 14" rims. I am sure that Michael King uses that very setup with the standard offset on his Tiger. I am sure Michael can confirm that.
by V8 burble » Mon Mar 12, 2012 10:01 am
gtsmrt,
Thanks for that. The Dales/Wilwood kit, whilst excellent, is just too expensive to import to the UK (for me anyway).
I am looking for hard info on wheel/tyre combos (preferably 14 inch) that work with Brembo calipers and do not foul the wheel arches.
TXJ7
by TXJ7 » Fri Mar 23, 2012 9:53 am
[quote="Brad1380
cheers
Brad[/quote]
Drawings (bit grubby, sorry!) with some dimensions. These are only as a rough guide, spacers need to be machined to fit your hub and disc combination.
Not shown on the drawings, but the bolt holes need to be counter-sunk so the spacer can fit against the disc. I also coutersunk the disk bolt holes as well to maximise clearance to the upright.
Here is the spacer bolted to the hub ready for the disc...
And the finished assembly again...
by Brad1380 » Sat Mar 24, 2012 8:33 am
Excellent, thanks for taking the time to draw it up,
cheers
Brad
by Brad1380 » Sun Apr 08, 2012 9:51 pm
Can you just remind me of the bolt PCD, it's not too clear on your diagram,
cheers
Brad
by Mal » Sun Mar 10, 2013 6:50 am
I have fitted the stock flexible brake lines to the calipers ( temporaily running no fluid), which seem to be the same thread. The problem is the hose hits the cross member on full lock.
Big Bob, as you have your flexible lines, if you put the steering on full lock does the hose hit the cross member.
It may not be a problem but I would rather it did not.
What have others used for their flexible lines. I think 90deg fitting off the caliper would be better.
Thanks Mal
redbaron
by redbaron » Sun Mar 10, 2013 11:49 pm
the original front flexible brake hose's from the Tiger,will be an imperial thread,of 3/8ths UNF and whilst these will screw into the Brembo calipers they are not the same thread,they use a Metric M10 thread.
You will need to obtain some M10 Banjo Bolts and Banjos to make some new brake hoses,the other end will be the original imperial thread,also the banjo ftgs will give you the clearance needed to keep the hose away from the chassis etc,just route them so that they point the hose up and to the brkt on the crossmember.
redbaron on Tue Jun 24, 2014 9:30 pm, edited 1 time in total.
