In for a penny
Post by Mal » Sat Mar 17, 2012 2:25 am
V8 burble wrote:Mal,
Have a look at the 10th post (for a full-size filter) on the Small Oil Filter thread in Tech Tips.
A full-size filter can then be mounted upside down in the original location in front of the LH cylinder head. The TRD-1075 with vertical ports is preferable.
A flattish steel plate with 5 holes (3 for TRD-1075 and 2 to match the cylinder head) is all that is required for mounting.
The block adapter (TRD-1413) fitted with my US Tiger headers without any problems.
Thank V8 burble, I will see if I can get the parts locally. Cheers
If preferred, you can use compression fittings with stainless braided hose instead of push-on 1/2 inch NPT barbs.
Post by Mal » Sat Mar 17, 2012 2:27 am
I am sure there is something missing, I think it was red :?
Post by gtsmrt » Sat Mar 17, 2012 4:33 am
8) At least the driveline will match the rest of the car Mal... Look great.
Post by Tomaselli » Sat Mar 17, 2012 9:21 am
That's so cool, never seen a Tiger naked before - great composition. More piccies please........
.... :mrgreen:
Post by Mal » Sun Mar 18, 2012 1:44 am
Here you go Tony. Paint it black and put shiny bits on it :mrgreen:
Post by V8 burble » Sun Mar 25, 2012 6:54 am
Mal,
Please note that the correct part number for the remote oil filter bracket (vertical ports) using 1/2 inch NPT fittings is Trans-Dapt #1028:
http://www.summitracing.com/parts/TRD-1028/?rtype=10
Post by Mal » Sun Mar 25, 2012 7:03 am
Thanks V8 Burble
Post by Mal » Fri Apr 06, 2012 2:43 am
Had another trial fit with the engine and headers, this side still needs two tubes altered.
This side is good.
Engine bay tidied up. Panel man said he couldn't leave the Jenson alterations like they were
We got it back on its wheels for the first time :D :D :D :D
Post by gtsmrt » Fri Apr 06, 2012 5:14 am
Looking good Mal. The front valance has come up well.
0neoffive
A Fine Project
Post by 0neoffive » Sat Apr 07, 2012 2:02 pm
Very good looking workmanship. I do like the mini valence scoop; from another vehicle or hand formed ?? Keep at it, randy 8)
Post by Mal » Sat Apr 07, 2012 8:23 pm
Thanks guys.
Randy, the upper half of the valence scoop is Tiger. The lower from a Honda which was a very close fit to the Tigers. Came with the chin spoiler which just hides the front suspension.
The vents in the bonnet are from the same car.
Post by martin172 » Sat Apr 07, 2012 8:59 pm
How many extra mph do you get with the propellor switched on? :lol:
It's looking really good now Mal.
How on Earth are you going to entertain yourself when it's done?
Don't tell the missus when it's finished. She'll find lots of jobs for you.
alpine5gt
Post by alpine5gt » Mon Apr 09, 2012 8:41 am
When your panel chap changed the brake/clutch to RHD did you have to drill any other holes beside the brake/clutch. With my Mk1 Tiger I am about to make the holes for the brake cylinder however any other holes needed for a RHD conversion would be appreciated. :lol:
Post by martin172 » Mon Apr 09, 2012 10:01 am
It left the factory as RHD.
Post by Ash » Mon Apr 09, 2012 12:50 pm
I just cut the holes for the clutch and brake cylinders when I converted my old lhd mk1a. If you use a mechanical throttle linkage you will need to drill a hole for that. I didnt bother as I used a cable and think it went through an existing hole but not sure as it was 15 years ago? :?
