Engine rebuild
Post by Tomaselli » Fri Mar 21, 2014 11:32 pm
Looking good Lou, will you be setting the engine up on a Rolling Road when your done? Highly recommended, that's if you can find somebody who knows how to get the best out of a Ford Small Block :lol:
Post by pushrod » Sat Mar 22, 2014 12:35 pm
Hi Tim
Real Steel in Uxbridge London did all the machining, advised on the best choice of parts to give me an engine to my requirements, (as powerful as possible for on road use without being a dog to drive in traffic). They also supplied most of the bits.
Lou.
Tim
Post by Tim » Tue Mar 25, 2014 10:53 am
Thanks for that; I didn't realise that Real Steel also did machining work.
Post by pushrod » Thu May 01, 2014 11:55 pm
Finally the car is up and running, drove it for the first time in six months yesterday.
Fitted the engine, gearbox and cross member a few weeks ago, since then everything that could have leaked has. Firstly the rear brake pipe was wrongly supplied, then I cross threaded the brake pipe where it connects to the new master cylinder necessitating removal and re-tapping, then the thermostat housing leaked water and more recently the oil pipes leaked.
So, now to run in the engine and gearbox in time for the Le Mans classic in July.
Engine and gearbox ready to be installed
Rear of car on ramps & front jacked up to give 3 foot of clearance to allow engine to pass beneath front valance.
Engine and crossmember in place
Headers blasted, sprayed and wrapped prior to fitting.
Ready for start up
Post by bigbob » Fri May 09, 2014 12:07 pm
Hi Lou, its looking good. I like the sump. Good to see we have the same washer bottle, if nothing else under the bonnet. Unfortunately injection plumbing issues mean car wont make this weekend's Sussex GT
Post by JAYANDSHEL » Fri May 09, 2014 6:00 pm
Glad its all coming together Lou
Don't know how you work under that bonnet Bob no room anywhere
