Page 38 of 38
Re: Brads Tiger
Posted: Fri Nov 12, 2021 3:38 pm
Well that's the car off of stands and on her new boots.
Just need to set the suspension up, get her road legal and then shake down.
Bit strange after all these years seeing her finished and the box of bits to fit being empty.
https://www.dropbox.com/s/bpuylu90osw56 ... 6.jpg?dl=0
Re: Brads Tiger
Posted: Fri Nov 12, 2021 5:36 pm
by garyf
WOW!!
The car looks absolutely Stunning Brad, well done
Is it M.O.T. Time?
Re: Brads Tiger
Posted: Fri Nov 12, 2021 6:18 pm
Yes it will be once i've got the suspension set up, that's looking like Xmas now with work commitments.
Re: Brads Tiger
Posted: Thu Nov 18, 2021 6:42 pm
by tgr747
Looking good,a credit to you.
Re: Brads Tiger
Posted: Sat Dec 11, 2021 8:00 pm
Thanks for the kind comments.
Slight delay to getting the suspension sorted as the wrong wheel nuts were supplied with the wheels and the supplier is out of stock.
No great worry as the amount of mud on the roads at the moment from all the rain and tractors around here she is best kept in the garage.
Re: Brads Tiger
Posted: Tue Jan 04, 2022 5:58 pm
Wheel nuts all sorted now, any recommendations on settings for the castor, camber & toe?
Re: Brads Tiger
Posted: Mon Jan 31, 2022 7:11 pm
3rd time trying to set up the suspension, made a proper front frame this time but still couldn't get the suspension on to its stops. Think the up-rated springs are throwing things out.
https://www.dropbox.com/s/l2q6iuwvdtqnf ... D.jpg?dl=0
Got the camber right on, castor is 2 degrees out not sure if i need to shim the cross member to sort that out. Also the ride height at the front seems too jacked up, maybe i should take out the spring rubbers?
https://www.dropbox.com/s/2kixoirbb7yzc ... D.jpg?dl=0
Re: Brads Tiger
Posted: Wed Feb 09, 2022 12:44 pm
by garyf
Brad
You may find when you use the car and have done a few hundred miles the suspension will settle
How much uprated are your springs?
Re: Brads Tiger
Posted: Fri Feb 18, 2022 7:35 pm
Not sure, they came with the car, but they seem pretty rigid, assembling the suspension was a proper trial.
Got both sides set up the same so at least it won't throw me in the nearest ditch, will check it all again after a few miles.
Currently going through the registration process, i have to get a pre-registration form to give to the MOT guy, then when he says the car is road worthy i can apply for the new number plate.
Re: Brads Tiger
Posted: Fri May 13, 2022 6:49 am
Hi Brad
Did you get the standard springs with the car. When i uprated the front springs they were shorter in height than the standard which makes the ride height the same.
You must be getting an itchy right foot by now. The car is beautiful and a credit to you.
Cheeers Mal
Re: Brads Tiger
Posted: Tue May 17, 2022 10:35 am
by garyf
Hi Brad
Just wondered what the latest was with your Tiger, have you sorted all the teething issues and is it on the road now?
Re: Brads Tiger
Posted: Mon Aug 01, 2022 5:12 am
Thanks Mal, kind words and if I hadn't of seen yours first I probably wouldn't have bought this one.
The registration process is taking longer than I hoped, it was moved from your local council office to online. Unfortunately the online system was rather circular with no way of getting to speak with a human to see what was going on.
This must have been causing problems as the FFVE have just launched a help site to assist with the process.
I have a set of updated springs from Sunbeam spares to fit along with Mustang II rubber mounts, so hopefully that will do the trick, then its back to camber /castor gauges and bits of string.
Re: Brads Tiger
Posted: Fri Nov 25, 2022 7:05 pm
Still need to fit these, its been a really busy year with working away and the wife has me building a new kitchen now i'm back.
Re: Brads Tiger
Posted: Wed May 24, 2023 3:04 pm
by garyf
Hi Brad
Just wondered what the latest is with your Tiger, are you on the Road now?
