by Mal » Fri Jan 04, 2013 3:52 am
Tom_HRO260 wrote:
Did you have to machine up a ring for the toploader to QT at all or were you able to use supplied adaptors? Are you using any kind of boot over the fork/slave assy at all?
Tom
Thanks Tom,
Yes I had to have a ring made up for the bell housing. The ones supplied were not right for the early toploader although the bell housing was supposed to come with all the parts for one. That would be my only complaint. Otherwise they are a nice compact bell housing. Thanks for putting me on to them.
I have no boot over the clutch fork. Probably a good idea. Do you know of any that will do the job ?.
Tom_HRO260
by Tom_HRO260 » Fri Jan 04, 2013 4:33 am
Haven't been able to track one down at this point. Lakewood do one but suited to the sharper radius of their housings so probably no ggod on the QT. Might risk the hydraulic throwout option...
- Site Admin
by gvickery » Tue Jan 08, 2013 12:14 pm
Tom. I see there are some nasty bush fires south west of Melbourne and worse in NSW.
I'll try to set up a Restoration section later in the week!!
Tom_HRO260
by Tom_HRO260 » Tue Jan 08, 2013 11:23 pm
gvickery wrote:Tom. I see there are some nasty bush fires south west of Melbourne and worse in NSW.
Hi Graham
Yes unfortunately the Australian summer has turned nasty again - Tasmania particularly badly hit this time around. The Bureau of Met has rejigged it's colour shading maps to cater for 54deg temperatures recorded last week.
Even made news in the old dart...
http://www.independent.co.uk/news/world ... 43297.html
That'd be a challenge for a Tiger's cooling system.
Thanks for the extra section on restos - I'll try to keep up the good work Mal, Brad and others have done in sharing their resto projects.
Cheers, Tom
by Mal » Sat Jan 19, 2013 3:01 am
by Mal » Sun Feb 10, 2013 4:32 am
Dynamat down.
I decided to use some Dynaliner as well up the firewall and where the header collectors are. Dynerlyner is to block heat.
Carpets cleaned and back down.
by meadowhog » Sun Feb 10, 2013 1:34 pm
I just looked back at your first page and saw a good looking Tiger, what made you decide to rebuild it?
by Mal » Mon Feb 11, 2013 5:50 am
meadowhog wrote:I just looked back at your first page and saw a good looking Tiger, what made you decide to rebuild it?
It didn't look to bad from the other side of the road did it.
It had a few rust bubbles coming through and you could see signs of bad repairs.
Never thought it would be as bad as it was.
That and the drivers door would open sometimes going around left hand corners
Now we know why
by Brad1380 » Thu Feb 28, 2013 1:29 pm
Mal wrote:Once I fitted the permanent extensions, centred the rack and had the wheels dead ahead I have even turns lock to lock. I didn't need to have more teeth cut into one end of the rack
Rack fitted
Mal why are the tie wraps done up differently, i.e. the ribbed section on the smaller ones is on the outside?
by Mal » Fri Mar 01, 2013 6:52 am
Brad1380 wrote:Mal wrote:Once I fitted the permanent extensions, centred the rack and had the wheels dead ahead I have even turns lock to lock. I didn't need to have more teeth cut into one end of the rack
Rack fitted
Your a hard man Brad
by Mal » Sat Mar 02, 2013 5:34 am
I got the exhaust done today. I wanted a cross over tube between the two sides which helps with power and sounds nicer. The rest is the old system. Something which allows me to fire the engine. I will get it redone once the car is up and running.
by Mal » Fri Mar 08, 2013 6:19 am
IT LIVES
NOT MOBILE YET BUT THE ENGINE IS RUNNING
by Tomaselli » Sat Mar 09, 2013 9:43 am
Youtube channel duly subscribed
Must have been a champagne popping moment, all you need now is a Go Pro video for the road trips from now on!
by martin172 » Sat Mar 09, 2013 12:32 pm
Hey, nice one Mal!!
Nice sound.
Have you had any complaints form the south island about the noise?
What's the padded thing you have got on the "rear seat"?
Any pics of it?
Nice period music btw.
