stuartb
Post by stuartb » Fri Mar 31, 2017 8:46 pm
Brad,
I can't speak for Cellulose but all my cars are painted in 2k which I am very pleased with, the AH 3000 is 2k base coat + Clear coat.
Stuart
Post by Brad1380 » Mon Apr 03, 2017 7:34 pm
Done a bit more research, modern paint isn't like the 2 pack i remember of old which looked like plastic, so going for water based base coat & clear coat, should be durable & not sag which cellulose does even years after being sprayed.
Post by Brad1380 » Sun Jul 16, 2017 6:00 pm
Bit more progress, leaded up the n/s headlight area after the repair section. Also been flatting down the body & trying to take out the dents where i can.
Also found these little brackets & no idea where they go, so any help would be appreciated.
TXJ7
Post by TXJ7 » Sun Jul 16, 2017 6:13 pm
looking good Brad.
The brackets are for the bootlid, left and right on tbe inside on the rear bottom edge (the rubber pads pointing downwards as buffers to the bodywork)
Post by Brad1380 » Sun Jul 16, 2017 6:16 pm
Thanks, they buttons are indeed rubber just painted over.
Getting there, just need a cash injection to cover the paint shop costs!
Re: Brads Tiger
Post by Brad1380 » Fri Feb 22, 2019 10:11 pm
Been a long time coming but she's away to a better place.
https://www.dropbox.com/s/str2ts2h1otpb ... 7.jpg?dl=0
Re: Brads Tiger
Post by gvickery » Sat Mar 02, 2019 6:33 pm
Looking good!!
Which paint shop and in which country??
Re: Brads Tiger
Post by Mal » Sun Mar 10, 2019 4:02 am
Nice to see it still progressing Brad. You must be pleased to see it of to the paint shop.
Re: Brads Tiger
Post by Brad1380 » Sat Mar 16, 2019 11:13 am
Yes big milestone to get it out the garage.
Now i have space its prompted a massive spring clean and clear up operation, there's grinding dust everywhere.
Re: Brads Tiger
Post by Brad1380 » Thu Mar 21, 2019 7:38 pm
Are there any differences between a Mk 1 & a Mk 2 for carpet sets?
I've been looking at Coverdale and they only list the Mk 2.
https://www.carcarpets.co.uk/sunbeam--tiger-373-c.asp
Re: Brads Tiger
Post by Brad1380 » Thu Apr 25, 2019 8:07 pm
Cars ready for viewing at the weekend as the painter has finished, bit apprehensive as to what to expect and it will be well weird to see it a colour after all these years.
stuartb
Re: Brads Tiger
Post by stuartb » Thu Apr 25, 2019 8:50 pm
Looking forward to a picture.
Re: Brads Tiger
Post by Brad1380 » Sat Apr 27, 2019 10:34 am
Last bolt on the cross member rebuild stripped so got hold of these heavy duty thread inserts, the tangs get knocked in afterwards to stop them rotating.
https://www.dropbox.com/s/z9668f9kzq0lg ... D.jpg?dl=0
Trial fit without the spring to make sure i tapped the inserts straight.
https://www.dropbox.com/s/jy5n9eztup794 ... D.jpg?dl=0
Re: Brads Tiger
Post by Brad1380 » Sat Apr 27, 2019 3:05 pm
Re: Brads Tiger
Post by Brad1380 » Thu Jul 11, 2019 2:18 pm
