steering wheels.
Posted: Wed Oct 28, 2009 7:29 am
I am going to buy a new steering wheel for the Tiger. One a little smaller that does not get in the way of my lanky legs. I was going to get a 13" but was warned it may be to small. What size are others using
and how do you like them
. I was also asked if it had tilt steering. To be honest I have not had a good look. What model did tilt steering start, or was it on the mk 2 only
Posted: Wed Oct 28, 2009 9:08 am
I recently purchased a Moto Lita steering wheel which is 14" and my Alpine steering wheel is 13" by memory. I have not installed the Moto Lita yet, but even with the Alpine's lighter steering you do work a bit harder at low speed. When you add another 200 Kg's for a Tiger I think you will notice it. I have never heard of tilt adjustable steering in an Alpine or Tiger. The Tiger's had the adjustable steering column (in/out) from what I am led to believe, but never tilted (or did they ?).
Posted: Wed Oct 28, 2009 9:19 pm
by JAYANDSHEL
We are using a 14 inch wheel which is from the ford RS range. It has a very thick rim in leather and find it ok at speed but is heavy when parking.
I think 14 inch is the smallest people use in general.
As a note of interest the spline of the steering shaft is the same as that from a mk1 escort or all of the capri range.
Posted: Thu Oct 29, 2009 2:09 pm
by odl21
i use a mota lita too.
they make a hub and horn button for the tiger which makes it straightforward.
i have a quick ratio rack too and the steering effort is fine with 195 tyres and a little heavy on 245 tyres
i like the wheel.
Posted: Fri Oct 30, 2009 6:03 am
Thanks for the replys. It is the Moto-Lita Mk 3 that I will get. I will go for the 14". Thanks again.
