ventilation
gregs302
ventilation
Post by gregs302 » Mon Jul 06, 2009 7:21 pm
Finally got tiger sorted so we took it over to Jersey.Had 2 glorious weeks with top down.Days hit nearly 30 c and we had no overheating probs,but inside car was roasting.Is this normal?The footwells and gearbox tunnel did get hot.my mk 1 has no air vents.are there solutions to this?
Ventilation
Post by gvickery » Mon Jul 06, 2009 10:51 pm
Cats Whiskers #72 carries the info you need - "Retro Fitting Fresh Air Vents and footwell ventilators. Can it be done?"
I don't recognise your monika so if you wereen't a member when #72 was published drop STOC an email and I will send the article to you.
STOC editor
odl21
Post by odl21 » Tue Jul 07, 2009 4:04 pm
it also helps a lot to lay foil covered insulation under the carpet. you can buy it in sheets that you cut and stick down.
