Just fitted a FAST distributor to my Tiger and the tachometer will no longer read obove 2000rpm.
Anyone know if the tacho can be modified to work?
Rev counter problem
Re: Rev counter problem
You may have to convert the tacho from RVI to RVC input, give Speedy cables a call they may help you out.
1966 Sunbeam Tiger Mk1a
You may get away with a MSD 8910 tach converter, someone else may know if it will work.
